Topic: Not enough headroom when recording 0 dBu into babyface
I'm trying to set up proper gainstaging in my setup, which has some synths/samplers going into my mixer and then the babyface's inputs.
When my mixer outputs 0 dBu the babyface peaks pass 0 dbfs because the babyface reference level is too low at +12 dBu, which means very dynamic sources clip when recorded out of the mixer at 0 dBu.
In 24 bit digital, it doesn't matter much if you record hot or cold but analog works best at 0 dBu...which is hotter on the babyface than most digital equipment.
It seems the babyface reference level just reduces headroom.
1) Can the reference level be adjusted?
2) If not, can there be an update with the adjustment?
3) What is the benefit of that reference level?
