Topic: USB-Audio and OSX, Known issue by RME, how about you?
Hi
I just want to put some focus on a Mac vs USB audio issue we experienced. It might help other users.
We set up a new system in august 2015, consisting of a brand new Mac Pro, and a MADIface XT.
The application requires us to run this with low latency, 15 hours a day, we tested with 32 samples, and it ran fine. So we set it to 64 to be safer.
The mac was cleaned, and all scheduled services and tasks where disabled, all power save features disabled. Turned off wifi, etc, and took the computer offline. All seems good.
Then we started having these noises like once or twice a day. Raising buffer to 128 does not change it.
It would sound like a sawtooth tone. looking at recordings we figured the noise was the last buffer looped for about 2 seconds. Something was clearly blocking audio.
Contacted RME through our local distributor and this is the response from RME:
This is a bug in newer OSX versions that affects any USB audio device.
The system seems unable to run for more than a few hours at a stretch withouth an interruption. As a simple workaround, it will help to unplug and reconnect the audio device
What? Why is this not more talked about? Can apple just break USB-audio and nobody cares?
So we put the madifaceXT in the trash, got a Thubdebolt PCI chassis and put in an old RME MADI PCIe card we had.
Now, the system is working fine. without USB
So just a heads up to anyone buying a USB audio device, planning to use it on a mac..
