Topic: Digicheck inaccurate display with Nuendo and Totalmix
Any help would be appreciated for accurate metering.
As of 12/22/16 Digicheck, UFX driver, UFX F/W, Nuendo 7 , Wavelab Pro, Windows 10 64bit all upgraded to latest S/W.
Correct Observation on Wavelab 9 Pro:
If I insert the Nuendo Test Generator plugin into the Wave Lab Pro 9 Main Bus out and set the Nuendo Test Generator plugin to 0 dB or any value, Wavelab 9 Pro Control Room meter displays the correct test generator output setting and so does the Digicheck H/W outputs 1 & 2. They are accurate display readings and values in both Wavelab Pro 9 and Digicheck without overs as expected.
Problem:
If I insert the Nuendo Test Generator plugin into the Nuendo 7 Main Bus out and set the Nuendo Test Generator plugin to 0 dB or any value, Nuendo Control Room meter displays the correct test generator output setting values but Digicheck H/W outputs 1 & 2 are inaccurate displaying wrong values with overs. Digicheck displays a much hotter output then the Meters within Nuendo.
I believe this to be an interaction between Nuendo 7 and Totalmix and Digicheck as it works fine between Wavelab Pro 9 and Digicheck.  Is there a setting in Totalmix and/or Digicheck to ensure that the host DAW S/W metering values are reflected accurately in Totalmix and/or Digicheck H/W UFX ouputs 1 & 2?
Any suggestions would be most appreciated.
Re: Digicheck inaccurate display with Nuendo and Totalmix
Probably a bug or set up fault in Nuendo! Had the same in Cubase. Look at all your vst connections and renew them if they are correct. It has been a while since I saw this but then removing and the adding all connections fixed it. It was confirmed by steinberg at the time.
HDSP9652+ADI-8AE  2X HDSP9632
Cubase pro10
3 (edited by bobe 2016-12-23 01:22:08)
Hi Vincent
Can you be more specific on what you mean to "renew" the VST connections.  Do you mean to delete the profiles and recreate them or to switch/reload current defined profiles?
Hi Vincent
This problem is a Nuendo problem. I will address the issue with Steinberg.
FYI: If I hit F4 and If I disable the Nuendo Control Room while having only the UFX Out 1 & 2 configured as Outputs under the Outputs tab, DIGICheck displays accurately.
or
When I hit F4 and I enable the control room, and click on the Studio tab and configure the Monitor Out to be anything but UFX Out 1 & 2 and Configure the Metering to "no connection", DIGICheck behaves correctly with no issues.
I am going to have to investigate Nuendo's Control Room behaviors and interactions in detail to see if there is a way around this behavior.  I will start with a deep dive into the Nuendo 7 manual regarding the "Control Room" features.
The reason I want this to work is I have a pair of Durrough RMS/PPM meters connected to the UFX 1 & 2 outputs for level monitoring and they need to accurately reflect DIGICheck's H/W Analog 1 & 2 outputs.
bobE
