Topic: UFX+ random digital clipping
Hi all, got a bit of an odd one with my UFX+ connecting via thunderbolt to a Mac Mini.
I have a couple of line inputs to the UFX+ which are then routed out via MADI to my sound console. I also have some ADAT inputs from another laptop. Very randomly (not very often to be fair) I get what a digital clip noise on the input channel that originate from the line inputs to the UFX+
I haven't noticed the same clip on the inputs that originate from the ADAT inputs.
I have tried a few scenarios to try and make it happen, but I'm not sure why it is doing this.
Has anyone else had this issue at all?
Many thanks
Christian
Re: UFX+ random digital clipping
I should have said as I am using Coaxial MADI i have tried clocking to this and also clocking to the ADAT input, both are showing solid clocks in the DSP Settings!
3
UFX+ firmware version? Mac OS version and RME driver version?
4 (edited by Lindsey 2017-04-09 15:58:01)
Hi Christian,
Please describe the routing exactly/precisely/specifically.
This will facilitate root cause analysis.
Some needed information is below.
Also please describe the rest of the setup as exactly as possible.
Thanks,
Linz
?line inputs from what?
?plugged into what input# of the UFX+?
?what input db setting?
?using what type of cable?
?carrying what signal (which instrument/voice/mix/synth/???)?
?via which output# on the UFX+?
?what is the complete routing from input source and description to output where the clipping is being heard/monitored?
SamProX23 Suite-RME UFX+,FF800;X-Touch,21" Acer Touch,ASUS ROG G750JH-DB71-Win8,MSSurfbook-Win10
