Topic: Digiface issue
Hello:
Three years ago I had saved a digiface. Yesterday, when connecting (last soft installed win and mac) it shows the following errors: the host LED was flashing, also the midi leds and the dsp soft alternately shows: rpm, digiface and multiface (dont detect correctly). Once I checked that the 1000 microF 50V capacitor was wrong; I changed it but the same symptoms continue. Any ideas?
Thank you
Re: Digiface issue
Use an external power supply, or if you do a different one. If that doesn't help then the transceivers for the data communication might be broken, on either unit or both.
