Topic: TotalMix routing to WDM and stream over LAN?
I'm using ASIO in Cubase and I have TeamViewer turned on. Is there anyway to route the audio from Cubase (ASIO) to WDM so that it can be heard by TeamViewer and sent over LAN? I know how to do it by changing the driver in Cubase, but I'd prefer to keep it ASIO for performance reasons.
Thanks!
Re: TotalMix routing to WDM and stream over LAN?
Anyone have any experience with this application? They claim to be able to do this: https://o-deus-audio.com.au/ASIOLinkPro
This app does it! https://o-deus-audio.com.au/Wdm2Vst
Thanks for reporting back!
It's always good to know there's another thing for the toolbox.
Did it work for you? I haven't tried it yet.
I sent Audio from Cubase (ASIO) over Skype by creating a loopback in Total Mix FX and selecting the corresponding Input in Skype. This should work as well in Team Viewer. Might be a little tricky but you can do it by just using the RME drivers.
