Topic: MIDI control problem
Hello.
I have a weird issue after upgrading to windows 10.
Controlling TM via midi just doesn't work anymore.
All my midi ports seem to work, but only in 64bit.
If I open an application in 32bit, all midi ports will fail to work.
But if I open the same application in 64bit, all is fine.
What makes me think that TM is running in 32bit ?
Any idea here ? It is just a must to have TM midi control.
Re: MIDI control problem
You might have to reinstall all RME drivers. There is no difference between 32 and 64, it should just work (and it usually does).
3 (edited by lebarde 2017-06-02 12:51:32)
Thanks for your answer.
Did all that, reinstalled all drivers for all audio / midi devices on my machine. Tried all midi I/O connexion possible to identify the source of the issue.
I got some grey hairs today to fix this tongue
I know it's not a TM related issue but it was affecting all my 32bit applications, TM included.
I found this registry fix and after hours of troubleshooting it finally works again.
https://support.serato.com/hc/en-us/art … in-MIDI-OX
yeah smile
