MC wrote:I do not see the benefit. This is just one (1) encoder. And you would need some kind of navigation which of the 18 or 30 or hundreds of inputs are under control. To me that makes no sense.
That was my 1st impression.
But thinking about it for a while this could be eventually useful when i.e.
operating a device with display in standalone mode and performing changes of gain/routing supported by ARC USB.
You would only require 3 new functions which can be assigned to the ARC USB keys.
1- submix select (selection of output channel/submix)
--- ARC USB encoder changes between output channels
--- Devices with Display might show the name of the mono/stereo submixes while selecting with Encoder
Descr: selects the submix for the further control
2- HW Input / SW playback select toggle
--- toggles between these two channel types
Descr: select which fader type you want to change for the selected submix and enables the encoder to browse between the HW input channels or SW playback channels
3- Channel select
--- r3d and last key to select the just selected channel to change the Gain with the Encoder
