Topic: Connecting Unbalanced Line to Balanced Input: UFX Plus
Hello my friends:
I cannot seem to find this info.
Can I connect Unbalanced cable (TS) to one of the Balanced (TRS) Input on the Back of the UFX Plus?
Thank you!
RME User Forum → FireWire & USB series → Connecting Unbalanced Line to Balanced Input: UFX Plus
Hello my friends:
Thank you!
See handbook 19.1
See handbook 19.1
Thanks as always:
But I have to say, there is no where on 19.1 where it states:
Balanced Inputs at back of unit can also accept Unbalanced Connection.
Unless I am losing my eye sight, these kinds of things should be very straight forward. Maybe even written next to the connectors themselves to avoid confusion and ambiguity.
Simple things like this should not require manuals, don't you want to focus on making music?
Thanks again as always for your tremendous help.
And it is simple .. you can use it for both
I only know one example of fairly recent pro gear that doesn't have servo-balanced I/O. It's stated in bold, in a very bold framework in the manual how to handle these cases.
And it 's in small print on the back of the unit.
Nobody reads it. In fact, a lot of people complain about noise in this unit, on the net. There's no noise, unless you leave pin 3 floating.
In 99% of the cases, you can assume that a balanced line input will also handle unbalanced.
So it's rather a case of "don't worry, be happy".
It says: The electronic input stage is built in a servo balanced design which handles unbalanced (mono jacks) and balanced (stereo jacks) correctly. So what else could this mean than exactly what you ask for? Unless you don't know the difference between a mono (TS) and a stereo (TRS) jack...
