Topic: software playback volume for main speakers ?
I understand this must be very basic, but I find the whole thing with audio levels from many different instances a bit confusing.
I am using small genelec monitors that have volume controls on them.
I have a fireface ucx with totalmix fx.
I am using ableton live as my daw.
* The master volume in ableton is set to 0db.
* The volume on the genelecs are set very low so that I can use the full spectrum of the main speakers fader in totalmix fx´s control room without blowing up my speakers or ears.
* The main speakers in totalmix fx´s controlroom is set to +4dBu
My questions are:
What should the Hardware settings volume setting be for AS 1/2 (my main speakers) in totalmix fx ?
What should the Software playback volume setting be for AS 1/2 in totalmix fx ?
To get the correct monitoring when working in the daw?
I now have them set to 0db. Is that correct ?
Re: software playback volume for main speakers ?
TM FX works internally accurate enough that you can reduce the volume safely up to a certain point, i.e. -20dB.
Its a good idea to reduce the total vol on your speakers with a little reserve for louder volumes.
See also this thread from MC: https://www.forum.rme-audio.de/viewtopic.php?id=25399
Thank you Ramses, but I still dont understand how to set the hardware output and software playback for AS 1/2 when mixing in my daw. Should they be set to 0db ?
In the DAW you set main output to 0dB because IMHO it makes no sense to set another volume there
if you prepare for the final mix or master.
In TotalMix I would let the Software playback at 0dB and adjust the final desiged volume with TM FX.
Or .. if you have it .. with ARC USB.
usually you should always buy a dedicated (passive, eventually I/O switchable) monitor volume controller, because by lowering output levels in totalmix, you're loosing the detail,
best scheme is to push everything to 0 (daw output, totalmix output, monitors gain) and just use a knob to change volume going into your monitors
HDSPe AIO, ADI-2 DAC, Fireface UFX, Octamic D, Octamic II
Reaper, High Sierra
Matthias, I remember you telling in another thread, that there is no big issue/loss.
Is this HW/ interface or fully TotalMix dependend?
What loss is this ? In terms of Bit resolution?
Is this somewhere documented? Or does smth like a diagram exists that maybe could tell me that ie -10 or -20dB on the master fader is still save ? Or that -30dB would result into a loss of xyz?
7
It's in the manual of the ADI-2 Pro.
