Topic: Madi FX card and two Antelope Orion32s
I have just recently decided to switch my recording process from hard disk to just interfaces into my computer, both for a better workflow and also to go to 96k, from 48k. The ins and outs are analog to my console, so I purchased two Orions to get my 48 chs. At 96, I only get 32 out of the possible 64 i/o. So I've connected Orion 1 to madi port 1 and Orion 2 to madi port 2. The setup is correct at 96 in the matrix setup, after ch 32 the numbering starts at m2 ch 1 and things are correct. If the card sees any of my 18 yrs of 48k projects coming in, the setup changes to 64 active on madi port 1, so all I can get is 32 ch of material off the first orion and nothing off the second. Will I have to manually repatch (daisy chain) both units to get all my channels to return at 48k? Is there a setting somewhere controlling the card that could be changed to accommodate the switch from 96 to 48k so I don't need to get to the back to manually repatch? Thx
