1 (edited by floyd pepper 2017-11-29 01:50:46)
Topic: audio playing on 2 channels randomly
aloha..
usually i have my audio routed to my main channel (AN 1/2) but it also happens a lot that its routing to AN 3/4 for some spontaneous reason.
which then i have to press CUE on AN 3/4 channel to hear the audio and vice versa.
i have this issue playing music through my music player, youtube and online streaming.
for sure this is a settings issue (i hope), perhaps anybody knows how to solve this?
greets greets
buy the ticket take the ride..
Re: audio playing on 2 channels randomly
Windows, Mac, what interface...
of course how stupido..
windows 10, rme fireface ufx ll
could it be a mono/stereo thing?
No. What did you set as number of WDM devices and which ones in the UFX Settings dialog? And what is set as Playback default in the System's Audio panel?
If the issue is only related to TM FX - easy to check. Save the current routing as Snapshot, and also as Workspace. When the issue returns load said Snapshot and Workspace. If that fixes the error then the settings in TM FX have been changed. This can only happen if you have MIDI control active and something sends control commands around.
hi mc
since i had 2 errors at the same time and not sure if they are related here my answer to jeff.
i dont intent to cross over for help but i saw you are online and im having this issue as we speak.
hi jeff thanks for helping out
yes i do, USB Diagnosis Fifo error 0 crc5 / 4.1 min (and counting)
buffer size 512
Input options: Optical 2 in [ADAT 2]
Output options: AES format (consumer) - Optical 2 out [AES/SPDIF]
WDM Devices: 2 [multi-channel]
Device name: Analog (1-8) and Analog (9+10) for my headphone.
Speaker: Analog (1-8)
Clock mode: single speed
Sample Rate: 48000 hz
Clock source: internal
About
RME MADIface
windows 7/8/10 driver
windows WDM and ASIO 2.3 support
Driver date: 17.02.17
Driver vers: 0.9606
Hardware reviseion: 15
here the post:
https://www.forum.rme-audio.de/viewtopic.php?id=26357
7
Yes, these errors might be the same. With USB transmission seriously disturbed mixing and channel assignment can also fail.
