Topic: Software Playbacks from PH 9/10 on disappeared after last update
Hello
I have a weird issue with Totalmix.
I use a Firface UFX and always been using Totalmix's entire functionalities for 2 years on Mac OS. Since the last update something happened to the software: Even though nothing is hide in channel layout, the mixer view in "Full mode" operational mode won't show some "software playbacks" channels anymore. In paricular it shows only from AN1 to AN8, but doesn't show 9 10, 11 and 12 which are the headphones outputs, and doesn't show all the ADATS. So I don't know how to handle the sends to hardware outputs.
Is that some kind of new features of the more recent RME version or just a bug o my mistake somehow?
The current version is 1.43.
Also, at the very moment i open Totalmix, it shows for an instant those channels (software outputs) and than they disappear immediately.
Please could anyone give me a hint about that? I'v searched on the web but haven't found any info.
Thank You!
Re: Software Playbacks from PH 9/10 on disappeared after last update
You either use a higher sample rate than single speed, or have set the Limit Bandwidth option in the Settings dialog to below All Channels.
That's exactly what escaped me!
Problem solved thank you very much!
