Topic: USB Driver development
Hello!
Im long time happy RME user from DIGI96 to UFX. And i have a bit strange question to ask developers smile
Is the RME usb driver based on usb-audio Class 2 (or class1) protocol? Or it uses full custom protocol with no any parts from standard usb-audio?
Thank you!
Re: USB Driver development
Fully custom.
Thanks!
One more question smile
Is driver works with bulk data transfer, or it uses isochronous data transfer?
And what requirements to using usb cable with RME devices? Something special?
Thank you!
There is no general answer to your question. We use Bulk, Interrupt or Isochronous transfers. The UFX+ for example can do both, Bulk or Isochronous transfers. You can choose what works best for you
Tnx for answer!
Just read fast UFX+ manual, and have no answer - how i can choose it?
And what abouit UFX - it has no choice?
7
You select the mode in the Settings dialog. The UFX has no choice.
Cant find this option...
https://image.ibb.co/jhOCPR/ufx.jpg
9
Well, if you don't understand 'Iso Streaming' then the manual willl tell you that this activates isochronous recording instead of bulk mode.
And really, all these questions make zero sense so far.
'Iso Streaming'
Thank you!
