Topic: ADI-2 Pro for 768 kHz measurements - what software do you recommend?
One of the use cases in the Introduction chapter of the User's Guide for the ADI-2 Pro is:
An AD/DA frontend for measurement systems at up to 768 kHz sample rate
Now I'm looking for advice on how to get the best use of the unit at the full 768 kHz. I need to measure and display
- the spectrum/noisefloor of external audio devices, using 1 or 2 inputs
- the frequency response of external audio devices, in loopback using 1 or 2 inputs and outputs
I normally use ARTA software and Adobe Audition, but both of these seem to max out at 192 kHz.
Reaper seems to handle 768 kHz, but it's not really an analysis tool and I'm not sure if it includes better spectrum analysis tools than a simple slowly integrating spectrum analyzer curve.
What other software do you use for 768 kHz measurements?
Thankful for any advice. :-)
Re: ADI-2 Pro for 768 kHz measurements - what software do you recommend?
May evaluate my SW on http://www.hpw-works.com ... wink
