1 (edited by kvn864 2018-04-13 05:55:53)
Topic: ADI-2 DAC, switch HP and line out outputs
Hello
I would like to find out if there is a way to program one of the buttons on the remote (1, 2, 3, 4) to switch output to headphone jack, or the line out, without pulling 1/4 inch plug out. I don't want them be ON all the time, but rather one or the other. For example: the headphone is playing, then I want to redirect the sound to line out on the back (the 1/4 inch plug is still in) so the speakers are playing now, and headphones are not.
Re: ADI-2 DAC, switch HP and line out outputs
See my blog article: https://www.tonstudio-forum.de/blog/ind … tup-EN-DE/
when I program "Toggle Ph/Line" to button 1, when pressed I get
Toggle Ph/Line
Function is off
I picked button 1 because I dont need "mono" function ..
Ok, so it seems to work, great wink
no, it doesn't. when I press the button, HP are still on, and line out isnt activated, I just see very briefly the message
Toggle Ph/Line
Function is off
on the display, no switching is happening.
6 (edited by ramses 2018-04-13 11:44:51)
The ADI-2 DAC is a little bit different, but based on the ADI-2 Pro settings it only requires this:
Options -> Device Mode
Mute Line  Toggle Ph/Line
Options -> HW/Diagnostics
Remap Keys: ON
I/O Key: Toggle Ph/Line
7 (edited by kvn864 2018-04-13 12:25:52)
Thanks, finally figured it out. Works well now.
Cool, thanks for the feedback.
I don't know if this is a proper place to ask but: I am using the unit connected to my PC via optical interface, and its sounds amazing. Is there any benefit to install usb driver and use that?
I want o use the 2nd DAC driving PH 3/4 as line output: is it enough to set to ON the Mute vs. TRS 3/4 setting (device mode menu paragraph 14.1.3). What about high power? Should I turned it off or it doesn't care il line mode?
DAW: W10 mini PC (i5)
Server: JRiver 30+Dirac+Acon Declick
DAC: RME ADI2 PRO Speakers ATC SCM50ASL
11 (edited by Mac Arthur 2023-12-12 07:55:36)
Remap Keys: ON
Thanks!
And then how do you move back and forth from headphones to line out setup?
Many thanks for your help
