Topic: found a bug
while using the ARC USB plugged into the RME UFX+ i noticed that when i engage the reverb using the ARC (i have made it so that snap 8 toggles the reverb) total mix crashes, or more accurately it hangs... as in it freezes and stops working all together, but when i hit my main snapshot to reset it, it goes back to normal functionality.. i even tried using a different hot key on the arc to engage the reverb but i get the same issue.. however when i toggle the delay it works fine.
i have all the latest updates.
anything im missing?
Re: found a bug
You use TotalMix FX 1.50 (3)?
