Topic: Brand new UFX II - Constant sound drops, screeching, and Fifo Errors
Hi I'm a bit upset,
I've been dealing with a problem where my brand new RME Fireface UFX II keeps dropping audio, some blips of distortion here and there, stuttering, and screeching during playback after a few minutes. Looking at the diagnostics, I keep getting Fifo errors and will get number codes like 30, 60 , and right now it's at 270.
Before you ask, I did do a lot of searching. My native USB controllers on my motherboard are Intel Based aka Intel C610 on an X99 motherboard where I have two seperate controllers. I'm plugged into the USB 3.0 port and not the USB 3.1 port. All ports return the same outcome. This is a Windows 10 x64 system.
Just for safekeeping, I JUST purchased a Sonnet Pro PCIe card which has 4 separate USB 3.0 controllers on it. I have nothing but the RME plugged into it. After about 2 minutes of playback, I got the same exact result...you can imagine how frustrated I am now.
I then tried to diagnose things around it maybe. I took out all USB based devices accept the mouse and keyboard (and even tried without the mouse and keyboard while playing the session), same thing. I'm running Cubase Pro 8 so I tried with and without ASIO Guard. Same thing...
The last thing I should note is that I am running the latest NVIDIA drivers, I'm using an GTX 1080 because I occasionally do video on this system as well. All drivers are updated. What also should be mentioned as well is that I do have the Intel I7 6800K OCed to 4.0, but I think I removed the RAM overclock. Granted, those settings shouldn't have an effect on USB performance especially when I'm now running the RME through a dedicated controller away from the motherboard controllers.
It's weird because the same session plays absolutely fine when I was using ASIO4All as a substitute playing through an MBOX till I got this hardware.
Desperately need help fixing this else I may have no choice but to send this back.
