mnszzz wrote:My DAC IO settings and SETUP settings cannot to be changed. I operated it following the manual. Is it a defect unit? Or any trick needed to chang the settings. The unit playbacks normally. Anynoe can help? Many thks.
Can you put a concrete example? What you wanted to achieve, describing the single config steps and then tell exactly, what did not work as expected by you?
BTW ... which model? Do you mean "ADI-2 DAC" or ADI-2 Pro/AE which is also a DAC from functional perspective?
Which firmware is in use?
