Topic: Audio interface vs Converter? UFXII or ADI8 MKIII?
Hi Mathias.C
Just wondering if you could give some highlights on the following setup:
Considering the following scenario:
1-dont need preamps (will use 500 series)
2-Best sound AD/DA (including Latency)
3-Will record 1 person at a time/only 2 headphones (1 for recording & 1 for monitoring)
4-Will consider connect to summing box in future
Which choice would be better:
1-RME digiface USB + ADI8MKIII (considering is the best AD/DA in 1U rack 8 channels after ADI8QS) + arc USB
2-RME UFXII + arc USB
Could you please confirm they are all compatible and Totalmix does support all functions trough Arc USB?
First choice:
I am assuming digiface USB can route all ins/outs from ADI8MKIII trough Totalmix and everything controlled by arc USB Regarding headphones connection would be one connected to TRS OUTS of the converter for the player and DIGIFACE USB headphones out for monitoring whats being recorded.
Second choice:
UFXII - have newer AD/DA so will it sound better?.....how about Latency when recording?
I notice dynamic range is higher on the ADI8 MKIII but UFXII AD/DA are newer.
Thks any suggestions for a similar setup are welcome.
Nino
