Topic: UCX, setting gain between 0 and 10 possible ?
In some cases with stronger signal I tried to set mic gain in TotalMix to value lower than 10 (but higher than 0) and it doesn't seem to be possible.
I guess this is a by design limitation, but it would be useful to be able to do so.
Re: UCX, setting gain between 0 and 10 possible ?
Actually, I will answer myself with quote from specs:
Gain range: 0 dB, +10 up to +65 dB
