Topic: adi 2 dac auto ref level or manual settings
hello again :-)
i have a Question. i use the adi 2 dac in combination with my violectric v 281 headphone amp i connect it via xlr to my adi 2 dac.
so far so good.
it is said that in the Manual the dbu go from -5 to + 24 (with xlr +6 db) the highest dbu i can chooose manually is only 13 and when i set my adi 2 dac to Auto ref Level the highest dbu i can reach is also only +13.( the Display on the adi 2 dac Shows this number)
so i know +13 dbu is loud enough and +7 dbu will fit perfectly but why cant i set it to +19 or +24 ????? i have fear tha t my adi 2 dac is broken or have somme issue with his Firmware??
thanks a lot for your advice
Alex
2 (edited by ramses 2018-06-17 10:46:55)
Re: adi 2 dac auto ref level or manual settings
In my ADI-2 DAC I can choose between -5, 1, 7, 13 dBu, Firmware version is v20. The handbook of the ADI-2 DAC tells at several parts in the text, that up to +19 dBu shall be possible.
Either +19 is simply a typo in the ADI-2 DAC manual or there is a selection missing in the latest firmware.
The ADI-2 Pro allows for these Levels: +4, +13, +19, +24 dBu, which is equal to the documented values in the technical specifications chapter of manual. Firmware v86.
3
Either - or - overlooked: The balanced output is always 6 dB higher.
And the +24 is a typo in an older version of the manual (most probably the printed one).
