1
Topic: Firmware Updates ADI-2 Pro 177 / 87 and DAC 17 / 21
The short version
Pro and DAC:
- Class Compliant compatibility for Windows 10 and Squeezebox Touch adjusted
- Dual EQ: save state to preset slot Temp after activation in the I/O menu
Only ADI-2 Pro:
- Level Meter of analog inputs simultaneously track pre and post EQ. This way overloads stay visible and Auto Ref Level works correctly even when the EQ is used to attenuate the signal.
- Added compensation filter for the AD-converter to reduce ripple in the frequency response for PCM, 44.1 up to 192 kHz, filter modes SD Sharp, Sharp, SD Slow, Slow.
Firmware download:
Win:
https://archiv.rme-audio.de/download/fu … ce_win.zip
Mac:
https://archiv.rme-audio.de/download/fu … ce_mac.zip
Re: Firmware Updates ADI-2 Pro 177 / 87 and DAC 17 / 21
Now into the details
This firmware update for the ADI-2 Pro and ADI-2 DAC extends the Class Compliant compatibility. While all our Class Compliant devices work perfectly on Mac OS X, iOS and Linux, we are aware that in some other cases they don't. The ADI-2 DAC was the perfect candidate to change that. We got a Squeezebox Touch from a fellow RME user, and also examined why Windows 10 recognizes, but won't start the DAC as playback device (as you may know since Windows 10 1709 a UAC2 driver is part of the OS, so it should work right out of the box).
The new FPGA firmware 177 (Pro) and 17 (DAC) is the result:
- Logitech's Squeezebox Touch with EDO via USB, which did not show the ADI-2 DAC at all, now recognizes it and can use it as audio source via USB.
- Windows 10 now fully accepts the ADI-2 Pro and DAC as 2 channel record and 2 channel playback device. PCM up to 384 kHz, and DSD up to DSD256 are supported.
The latter has been tested with various software, among them Roon. While Roon supports ASIO it can also use Wasapi to change the sample rate automatically based on the sample rate of the currently played file. This also works when changing to DSD (set to 'DSD via DoP'), everything automagically within a mixed PCM/DSD playlist. And although Windows audio is limited to 384 kHz, DSD256 playback worked perfectly - which switches the ADI to 705.6/768 kHz sample rate.
So basically there is no driver installation necessary under Windows 10 anymore - unless you want to use ASIO and DIGICheck and the Firmware Update Tool. And please note, once the driver is installed the same restrictions apply as before: with WDM there is only one single sample rate available, no automatic sample rate switching from the application via WDM or Wasapi - only via ASIO.
There is some more going on with the Pro. When switched to CC mode Multi-channel Windows sees 6 input and 8 output channels. In our opinion Windows' UAC2 driver needs serious updates to work flawlessly in multichannel mode, the list of issues is long, and therefore we can not recommend using it in that mode right now. Basically WDM/DirectSound somehow works, but the more interesting Wasapi Exclusive and many other things in handling and configuration are not working at all.
Note that in case you want to try it yourself: Windows already fails to adapt between Multi-channel mode and Stereo mode. When changing the mode you have to enter the Device Manager, Audio, Video and Game controllers, select the ADI-2 Pro, click on 'Uninstall'. After that go to Actions - Scan for Hardware changes. The ADI-2 Pro is back and will work now in the new mode. Going back to the former mode - same procedure again.
We hope that other reported Class Compliant incompatibilites (for example some Synology NAS, Sony HAP-S1) are also solved by firmware 177/17. Please report back here. And in case of trouble with the ADI-2 Pro make sure it is in Stereo mode.
These changes will be ported to our other CC capable devices sequentially. I also would like to point out that the changes do not affect operation under Windows with WDM/ASIO driver, iOS or Mac OS X, with one exception: all I/O channels now have names, so under Mac OS X outputs 1 to 8 changed to Analog 1/2, Phones 3/4, AES and SPDIF (Windows does not read or use the channel names). Whether this makes changes necessary in existing DAW projects or not needs to be seen.
ADI-2 Pro: ADC - to ripple or not...
Please click here for all the details.
https://www.forum.rme-audio.de/viewtopic.php?id=27295
First user report received: Synology DS213+, which did not work with the ADI-2 DAC and firmware 11/20, now works using firmware 17/21.
Successfully upgraded an ADI-2 Pro and DAC, many thanks :-)
Thanks for the firmware!
Firmware upgraded. Not more audio drop out. And now can work with Win 10 without driver.
Good job!
7 (edited by nefilim 2018-07-03 20:03:23)
Nice update! I did get a warning on OSX 10.3.4 about the flashing tool being a 32bit app and that 32bit app support is being deprecated.
Unfortunately still having issues with Roon + multi channel audio on Linux (fine on OSX): https://community.roonlabs.com/t/rock-n … on/43751/8
8
Thanks for the link, quite interesting. While I cannot exclude a fault on our side, Mac OS X working with both the old and new firmware in multi-channel mode clearly shows that it should work. Also the programmer of HQPlayer owns an ADI-2 Pro. I am pretty sure if that wouldn't work with Linux in general I would have been notified already.
The main problem here might be that multi-channel in CC mode just starts to get popular. See the mostly failing Windows 10 experience...
Thank you Matthias, I've surmised the same, the problem is most likely with Roon. I'll keep nudging them along to get to the bottom of it and hopefully provide a resolution.
In the mean time, enjoying my multi channel tunes (ala crossover convolution) with a Macbook Pro smile
Just updated my ADI-2 DAC yesterday and it works great with my windows laptop! I am wondering if the further update would add support for the Android devices. I have a AK SP1000 and really want to connect it to the ADI-2. Right now it could only play DSD files through the ADI-2 so I guess adding support to PCM files wouldn't be difficult.
11
That is a problem of your player or how you use it, not of the firmware or the ADI-2. When DSD works then PCM will work as well.
Yeah that's what bugs me. Usually it really should be working well on PCM if it could work on DSD. The thing is that when I plug my player in there, the sample rate of ADI2 just jumps to 768kHz directly, while on computers we could modify it with the software. Have you ever connected an Andriod phone to the ADI2? Are they working properly?
13
It jumps to 768 kHz because that is the highest sample rate supported (same on iOS). The app/software/player then has to set the sample rate of the currently playing file on the ADI, or perform a real-time sample rate conversion if it prefers to send out 768 kHz constantly...
Unusual power on/off behaviour after firmware update of two ADI-2 PRO.
After usage in my system I switch the ADI-2 PRO off (red led power button) and then disconnect main power of the whole system.
If I connect main power again (next day) both ADI-2 PRO will power up (white led power button). That occurs very often (let's say 7 of 10) even if I wait about 20 seconds after power off of the ADI-2 PRO before main power disconnect.
15
This happens when you push the button too long. Just push it until the display goes off. If you push longer you enter a (useless, we know) emergency shutdown mode which resets the memory of the standby button controller.
Thanks. I think I always pushed the button only as long as it took to turn off the display, maybe a tiny bit longer.
How long would I have to push the button for the "emergency shutdown"?
17
On older units 1.5 seconds, then the unit shuts down. If you push the button only until the display goes off the total shutdown time is 3 seconds. This function is not changeable via firmware update.
BTW, this is a topic from January 2018, firmware 159 DSP 85, two firmware versions back, and not related to 177/87.
I have checked what I was doing differently since the FW update.
I had activated "auto display off". So it is not possible to see the display turning off while pushing the power button because it is already off. I always waited for the LEDs to turn off and that is too long by far.
19
We are currently trying to add a visual indication of when to release the button for older and newer Pros.
Please note that we just got notified about a bug in FPGA version 177, which adds distortion on the analog recording signal's left channel at sample rates 352.8 kHz and higher. If you don't use these sample rates for recording PCM or DSD you don't have to worry. Otherwise please go back to the former version 174 / 86 with the former Flash Update Tools:
https://archiv.rme-audio.de/download/fu … 174_86.zip
An immediate update is not possible due to summer holidays, so it will take about two weeks until we can provide a fixed version of 177/87, which will have more changes that we finished working on already.
In firmware 180/88 the display will now light up when the unit starts to shut down, so you know when to remove the finger from the standby button.
And the bug mentioned in the previous post should be fixed as well.
https://www.forum.rme-audio.de/viewtopic.php?id=27467
