Topic: TM FX reverb not working MADIface XT
Yesterday we were overdubbing vocals through an Octamic XTC -> MADIface XT via MADI.
Artist was monitoring through XTC phones 1 in TM FX not the DAW.  When I turned on reverb and sent that input to the FX channel nothing happened (except the FX % went up).
Am I missing something basic?
Eastwood Records
www.eastwoodrecords.co.uk
Re: TM FX reverb not working MADIface XT
Did you also put up the small return FX fader in the channel of the artist?
Audio AG Support
Of course!  Classic send and return - thanks
Eastwood Records
Was that now a 'fixed' or 'not fixed'? If not, can you provide a screenshot?
I have exact the same problem with my UCX.  FX% goes up, but nothing happend. FX in segement is lighting but no FX out. I phoned RME Support. Unfortnuately very unfriendly man said i have to update my drivers. He even used teamviewer but could'nt fix the problem. But nothing changed. I reset everything still can't get fx. It was working just fine for a couple of years and i never moved my ucx. Fixed install in my studio. Can the FX section break? is it possible to repair?
We use the UCX for headphone Mix. Without effects the artists the signal is too dry.
6
The FX section can break, and it can be repaired. Contact your local distributor for details.
Sorry, just seen this. My particular issue was fixed, thanks.
Tjark, have you checked the relevant FX return levels on each output?
Eastwood Records
