Topic: New RME Madiface XT
Hi fellows,
I recently bought a New MADIface XT to be able to record a symphony Orchestra with a couple of Orion32+ converters as A/D D/A.
There is a few issues, first after 3-5 minutes the recording completely stops but playback will continue to run. 2nd The recording goes well for 40 minutes but next recording get glitchy sounds, sounds like some sort of digital feedback with a little echo, sometimes after 4 minutes sometimes after 15 minutes. The digital sound do not get recorded. If i re-select the sf or core audio or something else like shut Logic X down and restart the problem goes away for some time. The digital sound is only applied on the incoming sound. If I run the Orion32 via USB no problem at all running 4 days of recording more or less nonstop, but at the expense of 32 channels less.
Just want you guys to go through the settings because I have tried everything I could.
This is what I have done and in which order:
Disconnected the Orion32 (USB cable)
Increased buffer size
Muted/inactivated all other driver related stuff on the mac, internal microphone etc. etc.
RME Master (internal sync) Via World clock, Orion32+ Syncing Worldclock input.
RME Master (internal sync) Orion32+ Syncing MADI input.
Downloaded the newst driver for both Orion and RME.
Tried MADI 96k Framerate
Firmware update the Madiface
Changed the USB port
Reinstalled mac OS
changed the USB cable
Changed the Fiber cable (both OM4) 1 meter patch cable.
Cleaned the patch cable and the SC chassi connectors with fiber pen.
Here is a screenshot on my setup, please tell me where I go wrong:
https://ibb.co/kAqP2J
