Topic: Running two DAWs simultaneously using one Babyface Pro
Just discovered I can open 2 DAWs (Cubase and Studio One in this case) with their driver both set to Fireface USB and have low latency. Isn't that quite uncommon for an "exclusive" ASIO driver? And I can choose to record on either DAW, but not at the same time though. When I press the record bottom in Studio One then Cubase will detect audio dropout which is as expected.
Quite astonished to find out!!
Sebastian
