Topic: SPDIF connection and auto selection
If ADI-2 Pro is connected to a streamer through both coaxial and optical cables and the streamer is sending both SPDIF signals, if the ADI-2 Pro source selection is set to "auto" (left there as default) which SPDIF signal will be played? Obviously, if I set the source to either coaxial or to Toslink I will be getting whichever I choose, but which signal (coaxial or optical) I am getting if I left source set to "auto"? USB signal has been disconnected for this exercise.
Thanks a lot.....................Dr. larkos
Re: SPDIF connection and auto selection
I did the homework myself (apologies for my laziness)...it seems it defaults to the type of SPDIF source that was last used. In any event, the State Overview screen tells which SPDIF source is been used; if not the one you want just go and select it manually.
dr.larkos
Thanks that you share your observations.
I always take manually, because i had selections in automatic mode, which i did not understand
Adi-2 Pro, Adi-2 Dac Fs
