Topic: [Solved] Hdspe madi fx word problem
Hi guys i reached to madi fx from 9652, raydat, hdspe madi, finaly.
But sadley my card shows word is not locked. It's just linked through madi.
i tried with another clock generators and through another bnc cable.
It's just unlinked.
So i'm wondering there might be another setup though it's not indicated in manual.
Any advises would be welcomed.
i moved to win10 from win7 but it doesn't seem to be problem.
Cheers,
Re: [Solved] Hdspe madi fx word problem
Please set the card to internal clock and connect Word Clock Out to In directly - will that show up?
hi daniel, thanks for reply.
I tried to set internal mode and connect them, but nothing is happened..
Please be more specific - what does the Input Status for Word Clock show? Have you tried another cable?
input status shows no lock.
and yes, i tried with another bnc cable.
6
Are you sure you looped WC and not MADI?
WC is on the daughterboard which is connected to the FX mainboard by a 15 pin flat cable. Are you sure this one is correctly inserted into the sockets on both sides?
If so then the card might have a defective WC In or Out.
what a shame..
15pin wasnt connected..
There might be mistake while installing some of uad cards.
now it's working perfect.
sorry and thank you for help,daniel.
