Topic: ADI-2 Pro very hot
in these months the temperature in my studio is around 30 degrees
and ADI-2 Pro is very hot, so that it is difficult to touch the case.
Can this heat damage internal components?
It's normal?
Thanks.
Matt
RayDAT, ADI-2 Pro FS R, UCX
Re: ADI-2 Pro very hot
It's normal, but you should make sure the unit has space around it and is not sitting on top of another heating unit...
Thanks.
I proceeded to lift the card from the desktop about 5 cm to improve
cooling.
Now it's less hot.
dxmat wrote:
Thanks.
cooling.
Now it's less hot.
Good idea. I put taller feet on mine so that it has plenty of clearance from other units and I also took the opportunity to raise the front to a nice angle for viewing the display.
Perhaps try a USB-powered fan like this on the side next to the vent:
https://images-na.ssl-images-amazon.com/images/I/51LxT9GFIOL.jpg
