Topic: Can Octamic XTC be used in a MADI rig at the same time as CC?
As in, could the Octamic recorded to a computer/iPad whilst operating within a MADI chain as a preamp?
Eastwood Records
www.eastwoodrecords.co.uk
Re: Can Octamic XTC be used in a MADI rig at the same time as CC?
Yes, no problem.
Yes, no problem.
Awesome, so a viable backup solution alongside DUREC, providing the stems can be submixed to 22 channels within TM FX.
Does submixing have to happen within the host MADIface, or can the XTC itself take care of that (in case the MADIface loses power)?
Eastwood Records
The channels recorded are selected in the unit's display menu. But there is no mixer/submixes.
Okay, so if I set up a submix within the MADIface then routed it via the MADI stream to the XTC's recording channels, what would happen if the MADIface lost power?
Eastwood Records
Then the MADIFACE is powered off and doesn't participate in the MADI connection.
BR
Ramses
X10SRi-F, Win7 Prof, Cubase 9.5, UFX+, Octamic XTC, ADI-2 Pro FS BE/DAC, RayDAT, ARC USB
I get that, but my question is whether the submixes sent to the XTC out via TM FX will also be dropped?
Also, does the MADI loop continue when passing through unpowered devices e.g. MADIface?
Eastwood Records
If the interface is powered down then there is nothing there anymore that TM FX can control. Watch what happens if you power down the MADIface ... TM FX Windows closes immediately.
To second question. For me the MADI loop still works between ufx+ and 2 XTC if one of the two XTC's is being powered off. But tbh what should work if one of the two devices is powered off. The PC with the powered off MADIface will not receive anything anymore and TM FX is as I said also down as the driver has no connected interface anymore.
BR
Ramses
