Topic: Are output lines supposed to be ganged (Fireface UCX)
I am using balanced outputs on L1 and L2. However, when I try to select output lines I get L1, L3, etc. No L2. If I change the level on L1, L2 changes by the same amount. However, I would like to change L2 to be about 1-2db louder than L1. The manual suggests this can be done. Did I set something up wrong? If so, how do I correct it.
Fireface UCX
Balanced output to Classe Power Amplifier and HSU subwoofers.
