Topic: Loud crack in left channel during change input with different sampling
ADI-DAC (52973202) v23
COAX= CD
OPT= MacbookPro
USB= MacbookPro
When I playing music simultaneously from this two units at the same sampling frequency everything is OK.
If I change one source for example 96 kHz (PC) the problem begins to appear.
It is half of second muting and loud crack in the left channel (twetter) during changing the source.
Crack appear most of the time, it is lottery, but 70-100 percent of the times.
Always from changing PC to CD, no other way, always with change sampling frequency.
And only when signal is playing from PC.
If PC is muted or paused (no signal) no crack.
No matter OPT or USB is used.
Re: Loud crack in left channel during change input with different sampling
How do you change the input?
I use remote control.
I had find it out a few days ago during comparing my old CD"s vs newer remastered versions from spotify.
I was able to reproduce it. Fix should be possible, with the next firmware update.
Also eines muss man einmal sagen.
Ich kenne keinen Betrieb, der so fix auf etwas reagiert.
Alle Achtung und vollen Respekt - sowas finde ich sehr beeindruckend - Danke und BRAVO!!!
Adi-2 Pro, Adi-2 Dac Fs
Hammer .. und es ist Sonntag !
I did not expect a reply on Sunday. Next time if something happen, I will wait with the post until Monday.
I do not expect that someone will have to work on Sunday.
Anyway, an amazing company.
Best regards
This also happened to me using the encoders.
