1 (edited by ramses 2018-10-26 21:20:20)
Topic: ADI-2 Pro/DAC - remap key function
proposal: I would be very nice to have an additional remap key function "EQ+B/T+Ld all"
Reason: Its useful to have the following remap-key mapping below:
- Vol key: unassigned (to be able to switch through Volume screens or to leave configuration mode quickly)
- I/O key: Toggle Ph/Line
- EQ key: EQ+B/T+Ld 1/2
- SETUP key: Mute all
Then there is no key assignment left for both
- EQ+B/T+Ld 1/2 and
- EQ+B/T+Ld 3/4.
.. but it would actually be very useful to be able to disable "EQ+B/T+Ld"
no matter on which output channel you currently listen, be it 1/2 or 3/4, I have dynamic loudness enabled on both.
That would be very cool. Eventually possible by next firmware upgrade ??
Re: ADI-2 Pro/DAC - remap key function
There is no reason to not assign VOL. If all keys are defined you know that you have to press the button for a second and operation is still ok and quick. But we will check if <EQ+B/T+Ld all> is possible.
3 (edited by ramses 2018-10-27 09:49:29)
Hi Matthias, I looked deeper and can explain to you now, why I left the VOL key unassigned up to now.
After introduction and use of the remap-key feature I had to accomodate with new device operation
to press the I/O-, EQ-, SETUP- key longer, not to issue a re-mapped function.
At that point I didn't recognize, that its still possible to exit a menue by hitting the same key (short!) again
without issuing a remapped function.
This brought me to this kind of "workaround" to hit the VOL key 3x quickly instead, as its position is very thumb-friendly.
I hope I will get used now to exit menues by hitting the same button again, instead of using the VOL key.
EDIT: Just discovered that it will really take a while wink
But I think it would still be very useful to have
- EQ+B/T+Ld all
as it frees up one remap key location for another useful function.
While you are at it, maybe it would be worth to check for ease of use and "consistency",
whether also these functions could be implemented.
- Mono all
- Loudness all
- EQ out all
- BT out all
If you would ask me for a selection, whats more important that the other function,
then I would say
- EQ+B/T+Ld all (catches all of the others, Ld all, EQ out all, BT out all) and
- Mono all (to quickly check for Mono compatibility, how it sounds)
For my personal setup I am using now this:
- Vol key: Toggle Ph/Line
- I/O key: EQ+B/T+Ld 1/2
- EQ key: EQ+B/T+Ld 3/4
And it would be cool, maybe to be able to use this in the future:
- I/O key: EQ+B/T+Ld all
- EQ key: Mono all
Many thanks.
Based on the new findings, this updated: https://www.tonstudio-forum.de/blog/ind … tup-EN-DE/
Hallo Ramses, Du schreibst in Deinem Link bass/treble 7db beim adi2pro
Es sind aber 6dB
Oder habe ich was falsch verstanden?
Adi-2 Pro, Adi-2 Dac Fs
Es sind aber 6dB
Der Bass/Treble Regler an der Front (für "statische" Korrektur/Einstellung) hat einen Regelbereich +/- 6 dB.
In der Doku geht es um die "dynamische" Loudness. Regelbereich für Bass/Treble jeweils 1..10dB, default: 7 dB.
Ok - alles klar - Danke
Bitteschön, gern geschehen.
9
https://www.forum.rme-audio.de/viewtopic.php?id=27924
10 (edited by ramses 2018-11-29 06:50:42)
Extremely nice, also the other changes / fixes, many thanks for that :-)
Its i.e. very useful that the repeat rate has been increased for Enc1+2 to scroll up/down in configuration menues.
11
Yep. Before I never used that but pushed repeatedly. Much more convenient now.
