Topic: Adding Channels for raydat.
Hi daniel,
I'm considering add raydat for my 2nd system but it might be not enough for quantity of channels. (i need 48 channels)
So do you think it's possible to add channels on raydat with additional card?
Thank you.
Re: Adding Channels for raydat.
You can easily install/use a second RayDAT, but note that yxou will have two instances of TotalMix and no direct routing between the cards. The biggest limitation in that regard is using ASIO Direct Monitoring to one card's Main or Phones out. That won't work with input channels of the other card.
... but you could use AES/EBU or SPDIF to connect the cards to each other and transfer audio.
