1
Topic: UFX DUrec, format
two UFX DUrec questions
1) I am getting 'File System Error' message on the UFX built in screen, with a USB stick that has been formatted on  OS X Disc Utility to MS-DOS (FAT) with GUID Partition Map. The USB stick is recognized and functioning on the computer and other devices…
2) are CAF files supported yet by the UFX DUrec function - I am looking for a way to play back larger, interleaved multichannel files, that eventually exceed the .wav limitations of 2GB file size
any tip would be most welcome !
Re: UFX DUrec, format
1) The disk must be formatted FAT 32 with MBR (master boot record)
2) No, WAV only. Durec splits the files while recording to overcome the file size limit of FAT32.
