1 (edited by conor.paxton 2018-11-21 00:40:17)
Topic: RAYDAT out to Fireface 800 adat in, problems
I have recently purchased a RAYDAT for my Mac Pro (running Sierra). I got it to use with my Fireface 800, but I cannot see the output of the raydat in the Fireface 800 mixer.
I would like to route the adat out of the raydat to the main outputs of the ff800, and the adat outputs of the ff800 to the raydat in. Connection wise I have raydat adat 1 out -> Fireface 800 adat 1 in. Fireface 800 adat 1 out -> raydat adat 1 in.
I have searched the forum without luck, I have watched the tutorial on youtube about using 2 ff800s together but have not been able to figure it out.
I can get signal from the ff800 to raydat, but not the other way around. any help would be greatly appreciated.
Cheers,
Edit: I have the raydat set as master and the ff800 as auto sync
Conor
Re: RAYDAT out to Fireface 800 adat in, problems
Do you see "Sync" in the Fireface Settings?
Hi Daniel,
Thank you for replying. Yes, I see sync on both the Raydat settings and Fireface settings.
Conor
would you have any more info/ help?
