Topic: iPads with USB-C (2018)
I am using a new iPad Pro 2018.
My UFX ii in Class Compliant mode works but will not disconnect/reconnect when using a USB-B to USB-C cable. The hotplug mechanism doesn't work with this type of cable.
If I use a USB-C to USB-A female <--- USB cable, then it works. The hotplug is detected by the UFX.
Seems the USB-C hotplug in the iPad is just not giving the message a USB A/B device is expecting. I have an HP Envy with a USB-C port. When in CC mode, the very same cable will disconnect/connect.
One cable would be better. Is there anything stopping the UFX ii from being hotpluggable from the iPad's USB-C input?
