Topic: UFX+ MADI and Protools 32channel limit
I just upgraded to a UFX+, which i think will be a great location recording set up with a pair of XTCs.
I’ve managed to get the XTCs working with protools via MADI using loopback, but just wondered if there was any update on a mac driver that would allow inputs to be turned off to work more easily with the protools 32 input limitation.
At 96khz total mix doesn’t show ADAT 8-16 for obvious reasons, but they are still present in the driver - so it further eats into protools 32 channels since ADAT 8-16 aren’t available for loopback, but still eat into the protools limit.
I know this was much discussed a year or two back...
Re: UFX+ MADI and Protools 32channel limit
Yep, and it is still on our to-do list.
Thanks Matthias, good to hear.
Good to hear this. I’m also waiting for a reordering of channels in macos driver.
5 (edited by jetwolf 2019-07-19 03:00:42)
Any update on selecting the channels for Pro Tools?    Patiently waiting now for several years.   I was one of the first to buy a UFX+.
Please!!  I am running a Burl Mothership via MADI/UFX+.   Windows 10 using Thunderbolt.
Jetwolf
6 (edited by Origringo 2019-09-04 05:49:50)
Is there an ETA with being able to deactivate channels? I guess I realize that at the core it’s an Avid problem, and I’ll happily submit a ticket with them, but it seems other manufacturers have figured out how to accomplish this within their software in the past. I ended up just looping the MADI 1-8 back to ADAT 9-16 but it was after wasting most of my evening trying to figure a workaround that allowed me to use my Analog inputs for my outboard gear.
However. This solution doesn’t work at 96k where the outputs still show as available in PT but they are in fact inoperable.
Jeff
7
It's still on our to do list for this year. But I can't guarantee anything...
That's cool, thank you for responding. I had a nice chat with Jeff in support (who has been so awesome while I transitioned to RME btw) and he explained the complexities of making that kind of change to the driver.
Really, it's an Avid problem. Even at 96k when the inputs disappear from total mix they still appear in pro tools. It's really poor programming on their part (as usual.) As the user, if I am limited to 32 inputs I should be able to choose what 32 I want and not just arbitrarily the first 32 and it shouldn't be left to the hardware manufacturer to spend R&D on something that fundamentally changes their drivers that should easily be handled on the other end. I opened a support ticket with them expressing my displeasure, but I've been flirting with Studio One since they double the cost for a perpetual license for a while now anyway.
I suppose I could always record in Reaper when I need that many channels and import into PT at that point.
Thanks again for your reply. Loving my new RME products and your teams prompt attention and support.
jeff
Just wanted to bump this to see if it was still on the to do list.
Thanks,
Jerry
10
Yes it is.
Hi Matthias ...
Is the concept to be able to change the order in which blocks of inputs are presented, e.g., move the first 8 MADI channels in front of the 12 UFX+ Analog channels; or, to be able to select and specify any of the potential channels in a new matrix the way UAD does for the Apollo?
I'd love the latter designs with presets, so I could leave all my gear connected as I wish, but have different configurations instantly available for different applications.
Thanks.
DF
UFX+, ADI-648, Win 10, i7 10 core 3Ghz 64 Gb, Cubase 9, PT 12.8
Was wondering about the same question that bienpegaito posted. I also would love to have the preset option. Is this something that might be on the table for 2020.
Jerry
Jerry
I'm pretty sure that the worse part of this is after you exhaust your 12 analog inputs from, for example, the Fireface UFX+ and possibly the AES, you are left with 18 channels. But if you want to record above 48k, that is cut in half to 9 chanels as Pro Tools still is counting those as 18. You now have a total of only 23 usable channels.
There is a work around to use channels above MADI 3 (the 33rd channel as counted by Pro Tools) using your Totalmix configuration presets assuming that there are some connections among the 32 seen by Pro Tools that you don't need every time.
For an example, let's say you can live without ADAT 15/ 16 sometimes and want to access what is connected to MADI 23/ 24 which you use rarely. Select stereo linked output ADAT 15/ 16 and set it to loopback and then raise the fader from input of MADI 23/ 24 (could do the same from software input in the middle row).
In Pro Tools if you select ADAT 15/ 16 input, you will get the feed from MADI 23/24. You can keep this setup by using one of the Total Mix presets.
DF
Bump! I've been hoping for this for years and I'm about to have a gig where the lack of ability to reorder is going to give me a lot of pain. It would make a big difference for me as a customer. Thanks!
Same here, really hoping there'll be something for this soon!! Thanks RME!!
Time for my annual bump pleading for this feature.   Any progress?
Hello.
I just bought the ufx + and just realized it is useless since I can't use the madi with protools.
I really need this feature or I will have to send it back.
charlyston wrote:
Hello.
The workaround works pretty well.
I summarised here.
https://forum.rme-audio.de/viewtopic.php?id=31211
Been waiting for this feature for few years now. Hope it's still a work in progress.
Although this is a very specific problem with Pro Tools, I personally would welcome a feature where you could re-arrange your channel order at driver level with any RME interface.
Or this some kind of ASIO/CoreAudio driver specification/convention, where the channel order needs to be fixed and not modifieable by the end user? Just guessing because haven't seen this feature anywhere.
Avid is not likely to change this at their end, so please, RME, help us out here.
well, it is not an efficient workaround. it sacrifices 32 of my outputs.
It would be nice to have some feedback from rme.
a lot of people are asking for that feature. and it is on the to do list for a while now.
I bought a madi interface for my UFX + and now I can't use it with pro tools. Is RME still working on a solution?? (good luck getting pro tools to help!)
I really hope RME can do something otherwise I have bought a very expensive useless piece of gear and also only have 12 channels of IO!
benoit.morier wrote:
... otherwise I have bought a very expensive useless piece of gear ...
Of course we could argue you mean Pro Tools with "useless piece of gear", right? wink
+1
I thought that's what he meant, anyway! smile
On a more serious note, though,
@benoit.morier, you could use another DAW for recording(Reaper for example), and import laler into ProTools for mixing!
Annual bump.
Maybe the solution will appear for christmas
Hello RME, I would also very much appreciate a solution! smile
Yep, this limitation is reason I can't buy UFX+. If I want to run a couple of the 12mic pre's over MADI, I simply can't use Pro Tools with this interface.
I know the issue is Avid's, but this deliberate "flaw" in their software has been there for a decade now! I don't want a work-around, I want simplicity!
