Topic: Fireface UC: Random connection loss
over the last 2 days, I have experienced random connection losses to my Fireface UC when I connect and turn on my Access Virus TI Snow.
I should first point out that these two devices have been playing happily together on my PC for at least 2 years but now, suddenly, there is a strange problem I cannot seem to solve.
The problem started in Cubase 10, when I started using my Virus in Total Integration mode (audio and midi via USB) in Cubase, I would see this error message at random intervals (about 1-2 times a minute, coupled with a spike in CPU usage)
However, I soon discovered that the Virus only had to be switched on and the connection drops would occur. Furthermore, this behaviour is present when NO DAW is running and the Virus is simply switched on (not transmitting audio or receiving midi data from it's USB connection).
If I simply boot my PC to desktop, then turn on the Virus, I start to see the "HOST" red LED on the front of the Fireface UC illuminate at random intervals. The connection loss only happens for a split second, then the connection returns, but it causes audio drop outs when trying to make music and it even crashed the entire PC on one occasion. As soon as I put the Virus back in sleep mode, the problem stops.
I have tried removing/re-installing the Virus software and drivers, even tried moving the Virus to different USB connections (no hub, straight to my ASUS X99 Deluxe 3.1 motherboard) but the result is always the same.
The only thing that has changed recently is the driver version and firmware of the Fireface UC. I updated the drivers and firmware to the latest versions before this problem first appeared.
I have tried rolling back the drivers (not firmware) to 1165 and 1166 but the behaviour is still there. This leaves the firmware. Is it possible the firmware update is causing this? If so, is it possible to go back to an older firmware version?
EDIT: I tried booting the Fireface whilst holding in the rotary encoder to test with the "Safety BIOS" (version 86) but the problem persists, so I guess it isn't the firmware version 126 that's the problem.
I have never experienced ANY problems with the Fireface UC (or the Virus) until 2 days ago. I am running out of things to try!
I should point out that I am well aware this might be a Virus issue, so I have posted a similar message on the Access Virus user forum.
I am using Windows 10 64bit (latest version 1809) All software and drivers are up-to-date.
Any help would be greatly appreciated!
