1 (edited by GB 2019-03-24 21:51:40)
Topic: Babyface Pro Driver Error
Hi!
I´d appreciate any help with getting back the Babyface Pro working again on Win10.
The card was working just fine. I installed latest drivers, and the soundcard is giving problems to be recognized, also dissapeared from the "Audio Inputs and Outputs" in Win10´s Control panel.
Tried unistalling all RME drivers, even deleting any babyface registry entries, then reinstalling the drivers, changing the USB port, without luck.
Please find attached a pic of what I see in System:
Thanks a lot in advance for any help on this.
- Guillermo
Re: Babyface Pro Driver Error
The pic link didn't work. Is the BF Pro in CC mode? See manual.
3 (edited by GB 2019-03-25 11:31:41)
Hi! Thank you for the quick response, MC!
Ops, sorry about the pic. Let´s  see if this link works better:
https://photos.app.goo.gl/n2Zk8q5vyZRKc1DFA
Managed to get it working by installing previous drivers... Will investigate the other option at other time, as I´m in the middle of a mix now.
Thanks!
- Guillermo
The I/Os are gone if you select 0 for the WDM option in the Settings dialog.
Thank you MC, will investigate where to set that up.. I use ASIO though..
I can have a look remotely, if needed: rme.to/tv
