Topic: Adi 2Pro insert Hardware
I try to insert hardware into my ADI2PRO but whitout succes.
The main problem is that the Input is allways redirected to the output, so Insert a hardware unit for exemple betwen the TS output and going back is not possible.
Any idea about the setup to be able to do this ?
Thank you
Re: Adi 2Pro insert Hardware
The ADI-2 Pro is no recording interface, its a DAC and ADDA converter.
So combine RME recording Interface and ADI-2 Pro.
Described here:
HI thank you i'm a little bit disapointed, this is a very expansive unit and the AD DA is awesome, sad that I cannot use both simultaneously,
So you did not find the CC-Multichannel option? You can use the front output 3/4 to loop back to In 1/2 while monitoring the DAW via output 1/2...
The problem in fact is only the monitoring of the Input that is not working, I would to either to route it though headphone the second output.
Hi, I manage to find a solution connecting the hard between XLR 1/2 Output and Analog 1/2 Input. The monitoring is done via Headphone 3/4 output and by choosing the input of this output to be Analog. Also I can monitor from the Daw if I route my Input 1/2 to USB 3/4. My problem was that I did not notice that Phone 3/4 is on the left side and 1/2 on the right Side.
Thanks for helping
David
