Topic: FireFace UFX + ADI 2 FS Pro
Before to buy it,
- Is it possible to use the ADI 2 FS Pro as main output controler and/or as hi-end record converter for the final mix, following the Fireface in the chain?
- For example, If the ADI Pro is connected via AES to the Main Output (AES assigned) of the Fireface UFX, will it be available and visible in the Totalmix?
- And in this case, if the Pro is UBS connected, will it be reconise as the main outPut in Logic Pro (or Protools) and in the OSX core-audio?
I hope it's enough clear...
(Note I also own an ADI 8DS MKlll)
Thanks fot your help!
Gérard
