Topic: Inputs 9-12 (Mic/Line) on Fireface 802
I am wondering how Inputs 9-12 fare in comparison to the line inputs 1-8, found on the back of the unit? I currently have all 8 inputs used on the back of the unit and am wanting to add additional sound modules/romplers to my setup, so am going to be forced to use inputs 9-12 on the front of the unit, to make this happen. I am finding them odd to use, however. The back inputs are simple plug and play, where as the fronts tend to require more work involved and don't sound as good to my ears. Noisier? I see it mentioned that these have build in pre amps. Do these have to be used for synth connections, or just MIC?
I understand they are shared mic and line inputs, so this does mean that I can successfully hook up outputs of synths to these inputs and get a clean, reliable recording through them, right?
TotalMix FX is showing these are MIC 9-12. Is there anything I have to change in TotalMixFX to have proper connection and signal level for outputs from synths, so they read accordingly and not as mic?
I am really sorry if this is seeming like a stupid question, but to me, 9-12 just don't behave and sound the same as 1-8 and am hoping it is just something I am missing and if any hints, or tips can be given to get the most from these inputs, so they behave just like inputs 1-8 found on the back of the unit. These inputs can be used for synths without an issue right? They can behave and sound exactly like the back inputs?
Thanks so much for any time and effort put into answering this for me. If there is anything I am missing and these inputs are not what I should be using, please do let me know. I would like to be as clear as possible on what I am getting myself into, before I purchase anymore outboard gear to hook up to my 802.
