Topic: UFX 2 driver and totalmix not showing
I am a ufx 2 user. I bought it in December 2018 and was using it very well. But after I formatted windows10, I got a problem with the driver.
I installed the latest driver and grabbed the driver at the end of the twists and turns in Device Manager, but it does not work. In my ufx2 state there is a green light and a yellow light on cc and host
I formatted it several times and installed the driver but it does not work properly and I have madiface setting icon but the window does not come out. The same is true for totalmix.
Re: UFX 2 driver and totalmix not showing
what does "twists and turns in Device Manager" refer to exactly?
3 (edited by myengsung98 2019-05-21 20:26:36)
Force driver to grab
if you can, can you help me remotely?
Not sure what you mean, sorry. You don't need the Device Manager to install this - just run the installer...
I just installed it, but I did not get the driver.  Thank you for your comments !
The unit is in Class Compliant mode? Check in the display, Setup - Interface Mode.
