Topic: USB ALSA failures
I have a new ADI-2 DAC connected to Volumio on Sparky, and optical from TV. I leave Volumio powered on 24x7.
When first plugging USB cable into Sparky, ADI-2 DAC is recognized normally and music will play incl. 192/24 and DSD.
However, when powering off the ADI-2 and then powering on, the USB connection is lost - nothing showing on State Overview.  When I play a song, Linux on the Sparky reports "failed to open ALSA device h/w 2,0 no such file or directory". If I do a soft re-boot of volumio, the error persists.  If I do a hard boot (power off on on), the ADI-2 is recognized again, and State Overview shows USB connected - music plays!
Another condition is that when I power on the TV, the SP o shows a lock at 48 sps, but no sound.  I try various buttons such as select Optical etc. to no avail.
Any assistance to track down solutions to these issues would be greatly appreciated.
Re: USB ALSA failures
Point 1 works on any other OS, nothing we could change. Point 2: go to the Status overview screen. I bet the incoming signal is not audio. Change your TV setting to send out PCM stereo instead of Dolby..
It's true it is some encoded signal. The cable box allows to set the audio out to PCM but still not working. Not RME problem.
Consider resolved.
