Topic: Controlling ableton from ARC USB - problems
Hello
I cannot seem to get the ARC USB to send Midi data out that ableton can pickup, if I set midi out to RME ARC.. where does it show up? Or do I need to do some routing with 3rd party software?
I tried OSCULATOR and running the OSC out, but not all the data appears, for example Speaker B does not appear, but Mute groups do not, are mute groups in the midi set up?
www.yila.co.uk
Re: Controlling ableton from ARC USB - problems
That is not the intended purpose of operation.
Our OSC template includes Mute groups on the Reverb/Echo/Control page.
ah ok
made a mistake there, I meant to say speaker B switch does work with OSC out / Osculator but mute groups do not.. I wanted to switch between monitoring between totalmix and then monitoring in Ableton..
www.yila.co.uk
Ok I changed tact
Now I have Speaker B sending OSC out, Abletons Maxforlive device Touch OSC > then when I switch monitors it changes between my mains and smalls and turns off the phase correction software for the mains
www.yila.co.uk
