Topic: Changing input on Unit instead of remote
I'm wondering how to switch from USB to Optical on the unit. Currently, the only way I know how is with the remote.
Anyone know how to do it from the actual DAC?
Thanks,
Spence
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Changing input on Unit instead of remote
Thanks,
Spence
I/O button, then rotary 2
Hmm. That doesn’t work for me. Just get a bunch of settings. I have the adi-2 FS.
For the DAC, you have to make sure that the top bar reads the selected output. If it does not, rotate encoder 1 until it does. Then, go to 'Settings' by rotating encoder 2 with the second top bar selected (bold text). Then select 'Source' by pushing encoder 2 to go down and encoder 1 to go up and turn encoder 2 to select the desired input.
You can also use the remap keys function by saving the settings of the DAC with any input selected to a setup which then can be loaded by pushing the selected button on the DAC.
Otherwise, maybe a function to cycle through the inputs or select an individual input could be added to the remap keys function in a future firmware.
The only selected output I see is "line out" no "Source" option to change to opt or coax.
Have a look at the manual p. 20 (https://archiv.rme-audio.de/download/adi2dac_e.pdf) and try to reproduce the screen.
K. I got it now! Thanks much.
