Topic: Adi 2-Pro Manual
I have some corrections in the manual.
Page 20, chapter 12.1.2 Parametric EQ.
Band 2-4 Type
Is: Available settings are Peak and Shelf.
Should be: Available setting is Peak only.
Band 1-5 Frequency
Is: Adjustable from 20 Hz to 20.0 kHz in steps between 1 Hz and 100 Hz.
Should be: Adjustable from 20 Hz to 20.0 kHz in bands 1 t0 3, and 200 Hz to 20 kHz in bands 4 to 5, in steps between 1 Hz and 100 Hz.
And I have one question:
Why are the bands 4-5 different from bands 1-3 (Q and Freq.)?
Band 4 could be the same as bands 2-3, i.e. Q = 0.5 to 9.9 and Freq. = 20 Hz to 20 kHz.
Band 5 could be the same as band 1, i.e. Q = 0.5 to 9.9, Freq. = 20 Hz to 20 kHz and type settings Peak, Shelf, Low Cut and Low Pass (High Cut). Low Cut for using e.g. with additional tweeter or supertweeter.
Many Thanks,
S.
Re: Adi 2-Pro Manual
If I remember right it has to do with available processing power on the FPGA.
There were alread upgrades in terms of more flexibility compared to the 1st firmware version.
Hi
There is still an error in the manual.
Band 1-5 Frequency
Should be: Adjustable from 20 Hz to 20.0 kHz in bands 1 to 3, and 200 Hz to 20 kHz in bands 4 to 5, in steps between 1 Hz and 100 Hz.
Many Thanks,
S.
