Topic: Fireface 400 firmware error
Hello there,
I have had my Fireface 400 disconnected for a little while and now as I connected it back, It loaded up, but very slowly. And when I check the version driver is 3.36 but firmware shows v0.00.
I installed new firmware few months ago and it worked all well. When I try to install firmware update it shows "error 2000000"
Tried both firewire ports and for both the HOST LED is solid red. For one port it loads the total mix and in the RME settings it shows driver, but firmware 0.00 as i wrote above. For second firmware port it did not load at all. But still host is solid red.
Tried both buss and external power.
Any ideas what is going on?
Thanks a lot
Martin
