Topic: UFX+ vs ADI-2 Pro outputs comparison
Hello everyone!
Could anyone please help me to make decision for our project, which gear will be better suits our needs.
We already have one Fireface UFX+ unit, with mostly busy analog IO, in nearest future we will need 2 additional headphone outputs and 3 additional mic inputs. Limitation for this needs is 1U 19 rack slot, because it is for our sometimes-portable setup, now it is 3U with 1U free, and we think making it 4U is overkill and lack of mobility for our needs.
After some debates we trying to chose, where to go:
1. Another UFX+/UFXII unit with adat/madi connectivity with primary UFX+ unit
Pros:
good amount of additional reserved IO for possible future purposes
good quality of preamps and headphone outputs, which we think, suite our needs(we doesn't heard any better for now)
balanced headphone output scheme of ADI-2 Pro can be easily emulated with TotalmixFX
Cons:
the same grade device, which we already have, so no improvements in quality, only in quantity.
2. ADI-2 Pro with some 9.5" preamps like QuadMicII, for adat+aes connectivity with primary UFX+ unit
Pros:
possible improvements in headphones and main output quality
same grade mic preamps quality
suits our needs in connectivity
Cons:
there is no additional reserved IO for possible future needs
not so convenient in maintaining and configuration
3. Octamic XTC for madi connectivity with primary UFX+ unit
Pros:
most convenient combination with UFX+ (aux device feature)
better? quality mic preamps
good amount(5) of reserved mic preamps/analog IO for possible future needs
Cons:
30 Ohm headphone outputs poorly compatible with low impedance headphones, and we need it compatibility
All 3 choices costs nearly the same, Octamic XTC incompatible with low impedance headphones(IEMs etc), and now we chose between 1 and 2, so final decision depends on one point in our minds - are Adi-2 Pro outputs noticeably better than UFX+/UFXII and in which cases we can really benefit from this difference? Unfortunately it is hard to do side-by-side comparison in our region, so if someone on this forum has experience with both UFX+/UFXII and Adi-2 Pro, I will be grateful if you will share your opinion on this topic. Our main monitors are Adam A77x and our best headphones are Beyerdynamic dt1990pro and Sennheiser HD650 at this moment, and we have no plans to buy something considerably better(if it matters).
